Coby0711
Jan 26, 2023Follower
Intermittent Wireless connection
My netgear extender model EX3110 is having problems with the signal. It will work fine for a while and then it will stop working. Did not have this problem before. I already reset it and installed it...
Jan 27, 2023Guru - Experienced User
What router is it connected to?
when its having issues, have you logged into it through the browser and checked its backhaul status to the router?
Have you tried changing wifi channels on the router? Maybe there's interference
