sandyowens31's avatar
sandyowens31
Follower
May 18, 2022
Internet booster for Netgear 4 stream WifI 6 ROUTER ax1800 WIRELESS
ARE THERE BOOSTERS AVAILABLE FOR THE NETGEAR 4 steam wifi router AX 1800?
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Tell us what you are trying to do and someone might have some ideas.
    Maybe you want to make your wifi go further. If so, start here:
    WiFi Range Extenders: Boost Your WiFi Range | NETGEAR
    As to the AX1800, that is not a reliable guide to model number. Many devices come with an AX tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds. Netgear has made several AX1800 devices.
    Look at the label on the device for the model number.
