hultenlk
Jul 27, 2013Aspirant
Internet Download Speeds with WNR2000
We recently upgraded our Internet package and are supposed to receive download speeds of 20 mbps. When plugged directly into the modem I get 19.7. I get that a wireless connection is going to be slo...
jmizoguchi
Jul 29, 2013Virtuoso
54MMbps on wifi is using 20Mhz which is half duplex, single stream so you will see half the speed.
http://www.intel.com/products/wireless/adapters/5000/
You intel 5100 is 450Mbps capable which WNR200 don't but you need to change the wireless mode in the router above 150Mbps to get 40Mhz which will use dual stream which should show better performance .
