XCore420
Oct 22, 2019Aspirant
Internet Keeps Giving out and I'm ready to give up
Hello, so the WiFi-Extender I bought recently just does not work. No matter how many settings, how many factory defaults, how many times i have to move it. It will continously disconnect me from onli...
Oct 22, 2019Guru - Experienced User
1. how far from the router is it?
2. What router are you connecting to? Firwmare on it?
3. What is your house material made of? (details help because materials like concrete, brick, plaster lathe, adobe, hvac, foil lined insulation all block wifi signals to an almost unusable extent)
4. If you do a network scan, how many 2.4ghz signals are there? How many 5ghz?
5. Are you using fastlane?
6. have you tried moving the extender/router? Sometimes hvac within walls causes issues and moving an extender a few feet can make a big difference.
7. Occassionally the newest firmware causes issues and not fixes them as it should. Have you tried downgrading a version? If you do, make sure to do it over a hardwired connection and reset the device afterwards.
- XCore420Oct 24, 2019Aspirant
1. Maybe about 50 feet Max
2. Im Connected to an Xfinity Router
3. Not sure what house is made of, but doubt it's causing the issue.
4. Yes I have been using fastlane, the 5ghz to 2ghz wifi worked well for a bit but then eventually gave out and disconnected, google giving "DNS missing" error.
5. I've adjusted the channels many times, used the auto ones, and even changed them to the better ones, (2.4ghz, 1,6,11) currently using 44 on 5Ghz
- plemansOct 24, 2019Guru - Experienced User
XCore420 wrote:1. Maybe about 50 feet Max----appropriate distance
2. Im Connected to an Xfinity Router----not helpful as many isp provided routers a franky junk in my opinion.
3. Not sure what house is made of, but doubt it's causing the issue.---house materials make a huge difference. Hvac, concrete, brick, plaster lathe, adobe, foil lined insulation all do great jobs of blocking wifi. For those places that have those materials, we usually recommend a powerline setup or running ethernet throughout the house and setting up multiple access points.
5. I've adjusted the channels many times, used the auto ones, and even changed them to the better ones, (2.4ghz, 1,6,11) currently using 44 on 5Ghz----if you scan, how many of the 2.4ghz signals do you pickup and how many of the 5ghz.
When you state you tried everything in the book, have you tried downgrading the firmware a version or 2? Occassionally firmware updates have been what causes problems (search r7000 firmware issues). If you try downgrading, make sure to do it over a hardwired connection and to reset afterwards.
