Joe-Vaz
Jan 26, 2022Aspirant
Internet provider provided new Adtran router and my devices can’t connect to my EX8000 2.4 extension
My Internet provider replaced their old router with a new Adtran router. I connected my Nighthawk EX 8000 to the new router and kept the Extender's WiFi name and password the same as the router. I sp...
Jan 26, 2022Guru - Experienced User
When you setup the EX8000, did you use the wps method of setup?
Or did you use the installation assistant?
when you use the assistant, theres a section that asks you to extend both the 2.4ghz and the 5ghz. Uncheck the 2.4ghz. You'll still be able to use it but it'll force the extender to use the 5ghz dedicated backhaul. Tends to function smoother.
You're using the same ssid on the 2.4ghz for the router and the extender?
Does the new router have a "smart connect" or single ssid function?
If so, enable that and follow how I described above with the "uncheck 2.4ghz"
