SH-GTS
Sep 08, 2021Aspirant
Is a 120v power adapter multi-voltage and can be used on 220v mains?
Hi, I just recently bought and imported the Nighthawk Tri-band Mesh WiFi 6 System (Model: MK83) from USA. I was not aware this router's power adapter only supported 110-120v input. In my country its...
olympos1625
Sep 09, 2021NETGEAR Employee Retired
Hi SH-GTS,
Welcome to NETGEAR Community!
Thank you for reaching out. We are sorry for the confusion. The device itself supports 100-240V power input but the power adapter will be based on the region where you purchased the device. If you purchased the device in US, it will have a 100-120V power adapter only. You may still use the device by purchasing a universal power adapter that can handle 220-240V input with an output of 12V @ 2.5 Amperes. For you reference, please check the manual on page 126 https://www.downloads.netgear.com/files/GDC/MK83/MK83_UM_EN.pdf
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
SH-GTS
Sep 10, 2021Aspirant
Thank you for the reply and clarification.
In this case can you suggest where i can buy the correct original Netgear power adapter that supports 220v input and has the correct configuration? Or tell the adapter model number?
I want to avoid buying just any off the self adapter that may have different polarity/wattage and can damage the router.
Thank you
Thank you
