ETaylor10
Jun 20, 2021Follower
Is EX2800 WiFi Range Extender compatible with my NetGear Router model R6120
Is EX2800 WiFi Range Extender compatible with my NetGear Router model R6120. Do you recommend a different product to get internet service in another room in my home? Only 1100 sq ft, and I get a ...
michaelkenward
Jun 21, 2021Guru - Experienced User
No reason why it shouldn't work. Extenders should be able to connect to any router.
ETaylor10 wrote:
Do you recommend a different product to get internet service in another room in my home? Only 1100 sq ft, and I get a very poor internet signal in my dining room, separated from my home office by a hallway.
Try plugging your needs into the filters on the product pages:
WiFi Range Extenders: Boost Your WiFi Range | NETGEAR
and
Orbi: Whole Home WiFi System for Better WiFi Everywhere | NETGEAR
But given the size of your property, Orbi is probably overkill.
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
