dvdrw
Nov 17, 2020Tutor
Is EX6150 a real mesh extender?
Hello everyone, I would like to buy a wifi extender and just did some research. From my knowledge the EX6150 is just a normal wifi extener which can be used as an extender or AP. Howeve...
Nov 17, 2020Guru - Experienced User
Yes it can.
Just make sure you get Version 2. Version 2 supports the mesh operation. If its advertised as mesh, it should be version 2.
The version 1 doesn't support mesh.
- dvdrwNov 17, 2020Tutor
Thanks for your kindly reply.
- dvdrwNov 18, 2020Tutor
Hi,
I just checked the mannual for V2. It doesnt show anything about mesh:smileysad:
- plemansNov 18, 2020Guru - Experienced User
it was added in version 1.0.1.86. see the release notes
https://kb.netgear.com/000061579/EX6100v2-EX6150v2-Firmware-Version-1-0-1-86
Thanks
I probably just buy one and try it out. LOL
