ploppo
Jan 04, 2013Aspirant
Is it best to connect a WG602 to the PC or directly to the router?
I have just bought a WG602 v4 wireless access point. I already have a WIRED DG834 v4 router bought in 2010. I am wondering how is best to proceed with setting up the new WG602. On the box of my D...
jmizoguchi
Jan 04, 2013Virtuoso
Access point should have default IP which you should refer to manual
Go to support.netgear.com and download the manual.
You will require to setup accordingly and usually you will née to use Ethernet cable directly to the Access point for setup. Once that is done connect to existing network via Ethernet cable
