The_Hobbit
Jul 14, 2012Aspirant
Is it possible to WIRELESSLY connect the WN2500RP to the Airport Extreme?
Hey guys! I'm new on these forums, so pardon me if this has been asked before.
Anyway, I'm looking forward to buying the Airport Extreme, and use it as my main router, and I was wondering if my current Range Extender, the WN2500RP, is compatible with the apple's router.
Thank you in advance guys!
- jmizoguchiVirtuososhould work.... extender will JOIN the network by scan the SSID and use the encryption key you set on extreme base station.. use WPA2 and should be good
- The_HobbitAspirantThank you Jmi! I think I'll buy the AEBS today :D
