Skochkin
Aug 18, 2025Aspirant
Is netgear Ex7300 extender now obsolete?
It’s impossible to find answers online, so could you please be so kind as to help me with the EX7300 extender? I successfully used the ex7300 extender for probably 8-10 years with the Arris modem...
Skochkin
Aug 19, 2025Aspirant
It should also be a snap with the Nighthawk app. Well the app does not even support the EX7300. The nice thing about the new Xfinity Gateway is that for the most part dead spots are gone; signal strength is more than doubled sometimes tripled everywhere. The exception is the basement where I stream. It’s working fine without extender, but its prudent to get more signal strength there. The solution is one compatible Xfi pod at the foot of the stairs of the basement. I appreciate the higher WPA3 security, and will leave it at that setting. So I will be putting the Arris modem and extender on eBay at a bargain. I am sure this fine router and extender has some life left in it.
Aug 19, 2025Guru - Experienced User
Ya newer tech probably has more capabilities then the older EX unit. It's about 10 years old. Ya, won't be compatible with WPA3 security for sure. And be aware that if you have other older wifi devices, those won't be compatible either with WPA3. Unless you can get mixed Mode WPA2 and WPA3 enabled.
Ya get something more compatible with WPA3 and with the newer tech in the gateway that matches that for additional coverage.
Good Luck.
- SkochkinAug 19, 2025Aspirant
You seem very knowledgeable. This is the first time for me on this forum. If I sell the extender will the new user be able to at least update the firmware up to the point netgear ceased updating the firmwear? I set the extender to factor default so I suspect that included deleting any firm wear updates I had, though I never recall manually updating the firm wear.
- FURRYe38Aug 19, 2025Guru - Experienced User
As long as you or the next user can get the EX to connect to something supporting WPA or WPA2 then ya, they should be able to get FW updated to what ever last FW was posted: https://www.netgear.com/support/product/ex7300/#download
