Vas_Vadum
Feb 29, 2024Tutor
Is Nighthawk a scam? Dangerous? Data collecting? Seems like it.
I bought this router/extender 3.5 months ago. Every single month so far, it shut down my internet access and the only way to get it back was to load that **bleep** app on my phone. As soon as I loade...
Mar 01, 2024Guru - Experienced User
You detailed the issue you're having. Thanks for that. A couple questions.
1. What modem do you have from xfinity?
2. what router do you have? And what firmware is on it?
3. what extender do you have? And firmware on it?
I dislike the app and so rarely use it. Half the time, if I'm not testing something, I uninstall the app from my phone anyway because I don't use it. Its never caused an issue with connection. And you don't specify what app it is you're installing? The nighthawk app? Orbi app? Do you have bitdefender/armor? Just wanting to clarify.
When you're having issues, does it say "connected, no internet"? Does the SSID stop broadcasting entirely? Do wired devices drop? What happens when it comes back?
We're not there to see all that's going on or you experience so the better you describe what happens and is going on the better we can help.
Just an FYI, you're posting on the community forum where members of the public help out. We're not Netgear. Not trying to say you're not having issues. Just keep in mind that WE aren't Netgear and are trying to help you. So you can say whatever you want about Netgear and we don't care. But try to be courteous to the ones helping you and you'll get more help.
Vas_Vadum
Mar 01, 2024Tutor
I don't know what modem xfinity gave us, it shouldn't matter in the slightest, its also the router too.
The extender is the EX7300v2, Nighthawk app on android.
As per the other questions, I've posted on reddit about it as well but it was unhelpful. I have screenshot proof of the fact that they give you a 3 month only warranty and support, which is absolutely terrible. Right after the 3 month period I start having major problems too. A little searching online and you find that Netgear is actually really badly rated by a lot of people. Which I should have done before I got one but didn't because I remembered over a decade ago when I used one and it was a great piece of hardware.
So lets describe what exactly happened when I got fed up with all this finally.
First time I set this up, I used the app. I then found the IP address to load the router page on PC because the app is too limited to set up the device fully so I used the web page version to fix my network settings a little bit better. Xfinity was terrible and constantly going out at the same time every night claiming it was a hardware malfunction on our end, as if malfunctions occur at the same time every night... Most of the time, the extender would reconnect just fine when the connection came back on. However, there were times when it just wouldn't, and even with a reboot, it wouldn't. I found out that I had to load the android app Nighthawk, and connect it to the extender, just to get my network back. The connection would appear fine, everything would connect to the extender, but the extender would not provide internet until the android app made a successful connection to the extender.
Keep in mind I may call it a router on occasion because router, extender, same thing. I'm used to that, but I have to call it an extender here because people get all confused if I don't.
So a few days ago xfinity comes out and replaces our modem/router all-in-one system. The extender wouldn't connect anymore even though the network name and pass were exactly the same. I had to factory reset the thing. So I used the app to set it up, but it used the same network name so I couldn't tell if I was connected to the xfinity router or the extender. I couldn't access the extender's web page either... So I factory reset it once more. This time I tried to set it up via the web only as people claimed it was possible. It worked, my laptop set it up and connected to the internet. But no other devices could connect. They connected to the extender, but the extender would not give network access to anything. I was confused, so I loaded the android app Nighthawk, it couldn't find a device, I selected the extender from the list. It connected, suddenly every device connected to the extender had internet access while the app said it was an unconfigured device that needed to be set up, but wouldn't allow me to set it up either.
Yesterday, we had an 8 hour outage caused by a tornado that destroyed a lot of stuff in the area. The internet came back online on the xfinity device, but the extender wasn't giving internet access. I reboot it. Still nothing. I loaded the app on my phone. Suddenly the internet comes back on all devices connected to the extender even though the app still says its an unconfigured extender.
Every single case, in which the extender was broadcasting the proper network name for me to connect to but wasn't providing internet even though the main router was providing internet its self, I had to load that **bleep**ty nighthawk app to connect my devices to the internet.
Lastly, yes I know this is a community forum. Netgear doesn't give a rats ass about anyone but themselves. If they did, they wouldn't have a scam warranty and scam support system. However netgear may still moderate the forums or have people who do, that try to hide negative reviews as quickly as possible.
From my observations so far, its the app that is required for the extender to connect devices to the internet. As if Netgear has programmed their extender to shut down internet access if it doesn't see the app once every x time or when something goes wrong or has been rebooted. If the internet works now, clearly its capable of working. It doesn't matter what I am connected to, it matters that the internet comes back the very instant I load their **bleep**ty Nighthawk application on my phone. Literally, the very instant Nighthawk connects to the router, the "no internet" symbols on my devices suddenly vanish and everything begins working. I saw it happen on my laptop when it said no internet, I loaded the app on my phone, and within 2 seconds of the app connecting to the router, my laptop connected and my Alexa Echos began working and my robot vacuum's red indicator of no connection went away.
