Olu2942
Jun 21, 2020Aspirant
Is Nighthawk X6S ES8000 compartible with WiFi 6
Thinking of buying the Nighthawk X6S ES8000 WiFi extender. I want to future proof it, and would like to know that it will be compatible with WiFi 6 (802.11ax). Does anybody know?
Jun 21, 2020Guru - Experienced User
Do you mean the EX8000?
There isn't an es8000.
The EX8000 isn't a wireless AX device but that doesn't mean it isn't a great extender. its a triband and has much better speeds than a standard extender does because it uses 1 of the 5ghz bands just for router-----extender communication. None of the currently released AX extenders have the triband option.
It it does work on AX. I've used an EX8000 connected to my RAX200.
Olu2942
Jun 29, 2020Aspirant
Thank you
