Mobetterblues
Sep 14, 2022Aspirant
Issue connecting EX6100 to network
I have a ex6100 that was previously installed and working in a different home. When I plug the extender in, close to the router, for setup, the wifi networks that populate are EX6100_EXT_2GEXT and the...
Sep 14, 2022Guru - Experienced User
The EX6100 has an ethernet port on it. You can hardwire a pc/laptop into it for setup.
Have you tried that option?
Or tried using the option of setting up using the WPS push button method.
Mobetterblues
My router is not WPS capable.
When I connect my pc to the extended via ethernet, I have to same situation. I have an internet connection through my usual wifi network but I can't access the extenders network which it seems is where I am stuck.
