zambrelune
Jan 26, 2025Tutor
Issue setting up my netgear extender (ac1750 ex6250v2) and my netgear nighthawk M2 mobile 4G routeur
Hello, I have since 2 years a mobile mobile 4G LTE Mobile Routeur M2( MR2100) that works correctly but does not have a long range. I have recently bought a netgear extender AC1750 Wifi Mesh Extende...
Jan 26, 2025Guru - Experienced User
are you hardwiring the EX6250 into the M2 and setting the extender up in access point mode?
thats what I'd do.
the M2 is a mobile hotspot and the fcc limits its broadcast power significantly since it travels around. You might find that the extender provides plenty of coverage on its own.
- zambreluneJan 26, 2025Tutor
Thanks for the suggestion, I'll try that.
Regards
Serge
- plemansJan 27, 2025Guru - Experienced User
I hope it works well for you!
- zambreluneFeb 02, 2025Tutor
Hello,
I tried the suggestion ( thanks for it ) and it did not work at all.
I reset the extender to factory
I switch the button to access point
I connected the router to the nighthawk mobile modem 4G LTE M2( MR2100) and tried to do the setup
I finally accessed the extender and did the setup but :
-> no way to have a working connexion between the extender and the modem ( and the RJ45 cable works perfectly, the lights were on on the connectors on both sides)
When I am connected to the modem M2 , I do not reach the extender
When I am connecrted to the extender , it does not reach the modem
I did another test with another extender (from another brand) and it worked like a charm with the M2.
So this is very bothering.
I have a 4G Modem MR2110 from netgear and and extender from the same brand and they just do not work together when they work with other devices from other brands . This is frustrating as I bought the extender specifically to work with the MR211.
Any suggestion is welcome
Regards
SErge
