bocaboy
Jan 12, 2023Aspirant
Issue with N300 WiFi Range Extender
I have been using the N300, model EX2700 successfully for the last 4 years. I recently dumped Xfinity and started using T-Mobile Home Internet, which is working perfectly. My original configuration w...
- Jan 15, 2023
I reset the Extender this afternoon and voila, everything returned to normal. I guess moving from one ISP to another was something it didn't like! Anyway, a hard reset and then using the same SSID returned everything to normal.
Jan 13, 2023Guru - Experienced User
The tmobile device should have some type of attached devices page. You need to navigate to that to find out the netgears ip address. Then you can use that ip address to access the extender.
In terms of access point mode, no you can't. Reason why is the EX2700 doesn't have an access point mode.
bocaboy
Jan 13, 2023Aspirant
You would think that is so, but here is what I see when I track the EX2700 down via MAC address: no IP. If I switch to the WiFi network on the EX2700 and then check the details on my Macbook Pro, it has the same IP address as my Mac.
