TreyIvey
Jul 01, 2022Aspirant
ISSUE with Static IP via AC6250
I have an XR500 as my main router. I have a wifi (or direct connect) security camera that was out of range so added an AC6250 as an extender and then direct connected the security camera to the exte...
- Jul 09, 2022
By using the MyWiFiEXT page I was able to see the true MAC address. When I entered this address into the Static IP page / LAN CONFIG in the XR500 and clicked apply. That camera / MAC Address still was not getting the same IP Address I assigned. After 2 reboots of the XR500 it finally showed up with the static UP and has stayed the same since.
So the first issues U was facing was seeing the virtual address which did change so I could not get a static IP for them.
The second issue was whenever I finally knew the true MAC address, I did not think the assigned IP was sticking to the MAC address cause on Apply it did not come up with the assigned IP. I would then try other things which was confusing. It was not until I did Apply, Camera came up with non-assigned IP. I then recycled the XR500 and the camera had yet a different IP address. I recycled a 2nd time and it finally came up with the assigned static IP and has remained since.
Thanks everyone ... I have my issue resolved now.
Netduma-Fraser
Jul 03, 2022NetDuma Partner
Where is the camera getting the IP from the AC or the XR? How are you setting it static on the camera software or extender/XR?
- TreyIveyJul 03, 2022AspirantThe extender is an ex6250. I've tried a number to things. That's why I'm asking. I assume lan config in xr500 is where need to set a static. But it does not seem to stick. I think it is because of virtual mac.
- Netduma-FraserJul 03, 2022NetDuma PartnerYes that would be the place - is the extender showing on the Device Manager of the XR and does it get an IP? It shouldn't in theory but yes that could be why, does the extender have an interface you can change settings on at all?
- schumakuJul 04, 2022Guru - Experienced User
TreyIvey wrote:
That's why I'm asking. I assume lan config in xr500 is where need to set a static. But it does not seem to stick. I think it is because of virtual mac.From the XR500 view, your network security camera can show up with two different MAC addresses: When associated to the extender it's a virtual MAC, when it's associated to the XR, it's the camera real MAC. Depending on the access point the camera is associated, and because for each MAC DHCP can hand-out one IP address only, the camera can show up under two different IP addresses. Not sure which situation you see as "it does not stick".
- TreyIveyJul 09, 2022Aspirant
