TreyIvey
Jul 01, 2022Aspirant
ISSUE with Static IP via AC6250
I have an XR500 as my main router. I have a wifi (or direct connect) security camera that was out of range so added an AC6250 as an extender and then direct connected the security camera to the exte...
- Jul 09, 2022
By using the MyWiFiEXT page I was able to see the true MAC address. When I entered this address into the Static IP page / LAN CONFIG in the XR500 and clicked apply. That camera / MAC Address still was not getting the same IP Address I assigned. After 2 reboots of the XR500 it finally showed up with the static UP and has stayed the same since.
So the first issues U was facing was seeing the virtual address which did change so I could not get a static IP for them.
The second issue was whenever I finally knew the true MAC address, I did not think the assigned IP was sticking to the MAC address cause on Apply it did not come up with the assigned IP. I would then try other things which was confusing. It was not until I did Apply, Camera came up with non-assigned IP. I then recycled the XR500 and the camera had yet a different IP address. I recycled a 2nd time and it finally came up with the assigned static IP and has remained since.
Thanks everyone ... I have my issue resolved now.
schumaku
Jul 04, 2022Guru - Experienced User
TreyIvey wrote:
That's why I'm asking. I assume lan config in xr500 is where need to set a static. But it does not seem to stick. I think it is because of virtual mac.
From the XR500 view, your network security camera can show up with two different MAC addresses: When associated to the extender it's a virtual MAC, when it's associated to the XR, it's the camera real MAC. Depending on the access point the camera is associated, and because for each MAC DHCP can hand-out one IP address only, the camera can show up under two different IP addresses. Not sure which situation you see as "it does not stick".
TreyIvey
Jul 09, 2022Aspirant
