Gandhisflip
Aug 14, 2020Follower
Issues with Netgear ex2700 and Vodafone router
Hi there I've had real problems getting this to work - my Netgear range have worked with Sky / EE and BT routers in past. So finally completed a hard reset and now have the Vodafone EXT vis...
Aug 14, 2020Guru - Experienced User
Did you set it up via the wps method or using the installation assistant?
What vodafone router is it?
