armytroop
Jun 02, 2014Aspirant
Issues with WNDR4500 N900
I need to making access to restricted sites such as Army Knowledge Online AKO and MyPay sites avalible through my netgear router. I can access if I directly connect laptop to modem, but wireless. How do I configure my netgear so it doesn't block me from accessing these sites.
- jmizoguchiVirtuosoYou are in the a wrong section.
Router goes to router section and there is specific section for 4500
http://forum1.netgear.com/forumdisplay.php?f=116
Unless you enable some block service in the router GUI, It should all go through.
I would make sure router's WAN has public IP with the setup with your broadband been not detail the service type and model - armytroopAspirantThanks for the reply will check into it
