jom00151
Jul 22, 2026Follower
I've just switched off and factory reset and seem to now be able to connect
I'd seen this sooner, like you I have spent hours trying to fix the issue. I've just switched off and factory reset and seem to now be able to connect. :) The technical solution below is possibly...
Jul 29, 2026Guru - Experienced User
What did you switch OFF and factory reset?
