Robyn_ball
Sep 22, 2015Follower
I'VE PROBLEM WITH A lUMIA 930
I have a Lumia 930 and a Lumia 920. The second one when I try to connect a WN 604 It's OK, when I try with the first no.
the password is particularly long, 26 characters, but it's the same I use 920, why the 930 does not work?
1 Reply
- nhannNETGEAR Employee Retired
Hi Robyn_ball,
Try shortening or changing your password on the WN604. Then connect your Lumia 930.
Is your Lumia 930 able to connect to other WiFi networks?
You can also try posting your question on the Nokia Lumia 930 forums, to see if others have experienced the same issue on this device: http://forums.windowscentral.com/nokia-lumia-930/
