Braeknowe430's avatar
Braeknowe430
Follower
Apr 17, 2020
JGS524 conflicting with Apple AirPort Extreme when creating network
I have a home network set up as follows:-
Virgin Hub - 200mbs connected directly to an
Connected by ethernet and set at DHCP & NAT to an Apple Airport Extreme
I have created a Network with this and then have an ethernet cable going into the NEtgear Switch JGS524.  I have 4 airport Expresses peppered round the house - these are hard wired back to the Switch and I have several TV's and Apple TV's hard wired with CAt6 cabling all going back to the switch.
A few days ago my system went offline - I've been onto apple support and Virgin and reconfigured etc.  But the signal from the Swtich on all the products kept dissapearng and reappearing - I unplugged a few of the products and then directly plugged the into the Airport Extreme and they are all working fine.  It looks like the Switch is creating a DHCP (??) and conflicting with the Extreme - How do i stop this from happing so it's just a dumb (?) switch. Thank you
No RepliesBe the first to reply
