CF01
Feb 28, 2021Follower
Just Moved- Cannot remember password for mesh extender
We just moved and hit a barrier when setting up our wifi mesh extender. From the cell phone we can see the address for the extender, but when we enter the password. Its not the correct one. How ...
Feb 28, 2021Guru - Experienced User
You could simply factory reset it back to stock and reinstall it.
Push and hold reset for 7-15 seconds while its powered on.
then follow the install guide.
I'd recommend using the installation assistant and not wps.
