lucky64
Jan 14, 2012Novice
Lan led off on WNCE2001
Hello,
my WNCE2001 didn't work anymore; it worked fine for 4 days (I was able to set up it correctly) and connect it to my iMac. Starting from yesterday, it seems that there's no link between the lan port of the device and the lan port of my Mac.
I tried to power it off and on, but no result. I tried then to reset it (pushing the reset switch untile the amber led flash, but no way to connect again to the device. The lan led is always off and my pc is not getting any Ip from it. Tried also to use a Windows 7 Pc, but the ruslt is the same. Ipconfig shows that the cable is disconnected...
Of course I tried also to use a different lan cable.
Any idea about what could has happened? Am I following the correct reset procedure?
Any help will be appreciated...
Luca
Luca
1 Reply
- jmizoguchiVirtuosoit seems like defective unit. I would contact the vendor you purchase from return the unit
