Manterion
Jul 07, 2012Follower
Laptop does not see 5Ghz for WNDR3400v2
Hi all, I have the Intel Centrino Wireless-N 100 with the WNDR3400v2 wireless duel band router. For some reason, I'm not able to see (a/n)5GHz. It has its own SSID from the 2.4GHz. I'm able to conn...
Scubbie
Jul 08, 2012Apprentice
According to the "product brief" it should recognise the 5GHz channels. You may need to set you router to use a channel between 36 and 48.
It will only connect at up to 54mb/s though on the 5GHz channels.
http://www.intel.com/content/www/us/en/processors/centrino/centrino-wireless-n-100-brief.html
Could I suggest that you consider changing it for an Intel 5100, 5300 or 6200 card instead? Make sure that you get the correct size though as there are two sizes for that type of card and it will be screwed into the laptop.
