ezlaptop
Aug 01, 2020Aspirant
Laptop Suddenly Can't Find Extended Network on WN3000ROv3
On June 27, 2020 I successfully installed a WN3000RPv3 to extend the range from my landlord's wifi hub, in his basement, to my cottage, 35 feet away. I use a MacBook Pro, running Mac OS 10.15.5. I use...
Aug 01, 2020Guru - Experienced User
have you tried factory resetting the extender and re-running the installation wizard on it? (don't use wps)
- ezlaptopAug 01, 2020Aspirant
I'm trying to reply to plemens, but this interface is not at all inntuitive. Trying the factory reset option, now. But the http://mywifiext.local (likn for Mac setup) just doesn't work. The page just hangs.
