ezlaptop
Aug 01, 2020Aspirant
Laptop Suddenly Can't Find Extended Network on WN3000ROv3
On June 27, 2020 I successfully installed a WN3000RPv3 to extend the range from my landlord's wifi hub, in his basement, to my cottage, 35 feet away. I use a MacBook Pro, running Mac OS 10.15.5. I use...
Aug 01, 2020Guru - Experienced User
have you tried factory resetting the extender and re-running the installation wizard on it? (don't use wps)
ezlaptop
I'm trying to reply to plemens, but this interface is not at all inntuitive. Trying the factory reset option, now. But the http://mywifiext.local (likn for Mac setup) just doesn't work. The page just hangs.
