Nadeera's avatar
Nadeera
Follower
Jul 17, 2019
LED Power button blink on WNDAP350 wifi router
I have Neatgear WNDAP350 wifi router. It's power LED always blinking green and can not access LAN port. I tried to update firmwear using Windows TFTP. But defect is still available. please help me. thank you
1 Reply
  • plemans's avatar
    Here's what the description says. Indicates self test, loading software, or system fault (if continues). From the sounds of it, you've tried a reset, redoing it via tftp and still having the issue.
    this is one of Netgears prosafe devices with lifetime warranty on the device itself and a 3 year warranty on the power suppy. If you're unable to resolve it by updating over tftp, I'd try getting a replacement.
    Not sure how worth getting it fixed/replaced would be as its a 10 year old wireless N device. As much as I struggle getting rid of equipment, an upgrade is probably a good option when you're coming from a N300 device.
