Hmac
Feb 04, 2020Aspirant
Lights all green but no internet connection
Yesterday everything was fine, this morning I could not connect my iPad to the internet through the extender. I have rebooted the main hub (but internet on PCs is OK anyway), done a normal reset an...
DexterJB
Feb 04, 2020NETGEAR Moderator
Hi Hmac, welcome to the community! If you have done a factory reset then that clears all the configured settings. You will have to co through the setup process to get it connected back to the main network/router. The installation guide and user manual linked below may help out.
http://www.downloads.netgear.com/files/GDC/EX2700/EX2700_QSG_23Nov2015.pdf
http://www.downloads.netgear.com/files/GDC/EX2700/EX2700_UM_EN.pdf
Dexter
Hmac
Feb 05, 2020Aspirant
DexterJB - Many thanks for your reply.
I think the extender was faulty as I have replaced it with a different one, and everything is working fine now.
