sejarb
Jul 06, 2021Aspirant
Linking extender to new router
I just got a new wireless router; set it up with no problem. I can't get the extender set up. The Power & WPS LEDs light green. Client Link LED will (sporadically) light green, but not the Router Lin...
sejarb
EX7300 AC2200 Nighthawk X4. Thanks for the suggestion; didn't work.
Jul 06, 2021Guru - Experienced User
You put your extender but what router are you trying to connect to?
where did it fail in the process? "didn't work" doesn't tell us anything of what happened, where it failed, or much of anything
- sejarbJul 06, 2021Aspirant
The router is a TP-Link AC1900. "Doesn't work" means no NETGEAR_EXT appears as a connection, and the Router Link LED still does not light up indicating connection with the router.
- plemansJul 06, 2021Guru - Experienced User
1.tplink makes a lot of ac1900 devices. AC1900 is a speed not a model.
2. If you factory reset it, you won't get a connection to the router unless you install the extender.
3. What are all the lights doing? Color/blinking/etc
4. did you push and hold reset for 15 seconds on the extender while it was powered on?
5. another option is to hardwire a pc/laptop into the extender for setup. Just make sure to disable the pc/laptops wifi so it doesn't default back to that connection
