CapeJoe
May 20, 2019Follower
Log In after Installing Wifi Extender
I have successfully installed (and registered) the Wifi Extender. It is not clear to me what network I should now connect to....my current wifi network as usual? The video says I should now see my "n...
May 20, 2019Guru - Experienced User
Please post about this in the extender forum:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
Thank you.
CapeJoe wrote:
I have successfully installed (and registered) the Wifi Extender. It is not clear to me what network I should now connect to....my current wifi network as usual? The video says I should now see my "normal" wifi network with an --EXT extension. Should I be seeing that in addition to seeing my "normal" wifi network without the EXT? If my system automatically goes to this "normal" wifi network without the EXT, do I need to log in again to the EXT network and change the auto settings? I have no idea whether I am now connected to the extended network or not. Would very much appreciate some guidance here.
