Randomisation21
Sep 05, 2019Aspirant
Log In Details
I have to reconfigure the Netgear settings as noe I have a new router and typical in these situations the staff member who set up the network no longer works for this organisation What isthe easie...
Randomisation21
Sep 13, 2019Aspirant
Thank you Christian appreciate your response the only issue we have is we don’t really have IT specialist with this now has as the set up wax awhile ago and I can’t quite see what I need to do is there any net gear support team I could ring when I’m actually connected in the office to see if I can get some help ? They way the WiFi is plugged in at the moment means i Router is plugged into a lan socket It’s loops via a distribution cabinet that plugs in Apple Time Capsule which we need to have on the network and then back out into the room and the fact and we think that’s what I was in the dropouts as it’s having to work too hard I know that the EE signal into the building iso the wiring could be causing me a slowing and dropouts
Christian_R
Sep 19, 2019NETGEAR Employee Retired
Randomisation21 - I have sent you a message. Please respond at your earliest convenience.
Christian
