EZ123
Dec 23, 2015Aspirant
Looking for a device which wiil enable me to establish a local network
Hi, I'm looking for a device which will enable me to: 1. Establish a local WiFi network, and connect several mobile devices to a this local network (no internet connection needed) 2. Outdoors, ...
TheEther
Dec 23, 2015Guru
If you are willing to sacrifice wireless security and don't need a lot of bandwidth, you can just use a Windows or Mac laptop to create an ad hoc Wi-Fi netework.
Since you have no need for Internet access, I would not recommend the mobile broadband hotspots. You'd be wasting money on the unneeded cellular modem. But come to think of it, if you have a smartphone with hotspot enabled, you could use it as a local network.
You didn't specify the range required for your outdoor Wi-Fi network, but any of the Wi-Fi routers should work. The PR2000, being a travel router, may work only over short distances.
EZ123
Thanks for answering.
Some more input:
1. Security is not an issue
2. I do need a lot of bandwidth, and quite a lot of devices (couple of dozens), although for start few devices will do fine
3. I prefer not to use a laptop, since I need a mobile and lightweight solution
4. I need a range of about 10m radius
5. I guess that a smartphone with hotspot enabled won't be enough for a lot of bandwidth and more than a few devices...
Appreciate any solution that could meet these needs :)
- TheEtherDec 23, 2015Guru
How much bandwidth do you need per device?
Do you have any idea if the devices can do 5 GHz or will they be 2.4 GHz only?
Since this is outdoors, is A/C power available?
- EZ123Dec 24, 2015Aspirant
Need enough bandwidth for Voice over IP.
No - no idea about 5 of 2.4 GHz - why is this a consideration?
A/C power is not available, but I can take a battery, or better - get a device with a built in battery, like on of these:
- TheEtherDec 24, 2015Guru
5 GHz vs 2.4 GHz is a consideration because there is much more bandwidth available at 5 GHz than at 2.4 GHz. But Voice over IP is not a high bandwidth application, so you may be able to get away with just using 2.4 GHz. Besides, without A/C power, that really limits your choices to travel routers unless you use a DC to AC power inverter. Almost all travel routers are 2.4 GHz only. The only dual band travel router I can find is made by D-Link but one review said that it's limited to 5 devices which, if true, would not meet your needs. Any N300 class travel router that can support a couple dozen of users should work.
