JohnKuzn
Oct 09, 2020Initiate
Looking for a MESH Extender
I am replacing my WiFi network. Had installed it in December 2014. I had a Netgear Nighthawk R7000 and 2 Netgear extenders. I live in a New York coop with wire mesh walls and plenty of local inter...
schumaku
Oct 09, 2020Guru - Experienced User
Everybody around your apartment does the same. All try to put up more power, more Mesh systems, illegal antennas, high-power WiFi equipment, HDMI extensions over wireless, wireless audio systems, and much more. Everything does happen on essentially two bands, resp, one 2.4 GHz band and two 5 GHz band parts (and the bandwidth hungry ones use all). What is going on over the air - a single shared medium with a very small public frequency band(s) available - will hit whatever issues. Collisions, interference, ... nightmare!
There is only one advise: Install network cables from your router (somewhere at a central place, or near to the Internet [two-wire, cable TV, fiber, ...] inlet into all areas of your apartment where you need coverage, and better coverage. Add wireless access points in each of these network cable outlets.
