pjh1
Nov 01, 2015Aspirant
looking for suggestion for extender
I am looking to extend a 2.4G and 5G network using the same SSID (do not want to create xyz_EXT). Modem is an Arris T1672 and using both 2.4G and 5G networks. Looking for recommendation for a WiFi ...
- Nov 01, 2015
According to this Knowledge Base article, you can use the same SSID. They just warn that performance may vary because it will be entirely up to the device to determine which signal (i.e. the modem's or the extender's) to lock onto. But that situation is likely to occur with different SSIDs if the device knows the passwords to them.
Note: The EX6150 is not listed as a product that the article applies to, but I would be surprised if it doesn't.
TheEther
Nov 01, 2015Guru
- pjh1Nov 05, 2015Aspirant
EX6150 worked great.
