rk911
Nov 08, 2018Aspirant
Looking For Wifi Extender Recommendation To Replace WN2500RP
currently using a Netgear WN2500RP to extend wifi in my home and it does a pretty good job. but because of the design and layout of the house the farthest room from the router and extender has minima...
rk911
Nov 09, 2018Aspirant
StephenB wrote:
What router (manufacturer and model) are you using? If you have a newer dual-band router with 802.11ac, it would make sense to get an extender with similar capability/speed.
A model with external antennas might have more reach, but you might need to go with multiple extenders. One of the "mesh extender" models would make sense then, since it is intended for that. One caveat is that the mesh extender features are pretty new, and there are issues being reported here with the current firmware. Though I believe Netgear will resolve those (hopefully soon).
One option (though more expensive than adding or replacing an extender) is to use an Orbi system to get whole-house coverage.
____________________
good morning, stephen. the router here is a MediaAccess TV8305C (Comcast). docs say it is an 802.11 b/g/n. don't want to replace the current modem/router if at all possible. our "landline" phone service is also provided by Comcast. my first thought was to add a second extender but i'm thinking to just replace the current 2500RP and see if that helps.
Nov 09, 2018Guru - Experienced User
rk911 wrote:
the router here is a MediaAccess TC8305C (Comcast). docs say it is an 802.11 b/g/n. don't want to replace the current modem/router if at all possible.
That is an older router model that is 2.4 Ghz only. Using an Orbi as an access point would give you whole house coverage and better wifi - you'd still keep your current router, all you'd do is turn off it's WiFi.
If you want to stick with extenders, then an N300 or N600 is the right speed grade. I don't think any of those models will give you more reach over what you already have.
So I am thinking that you should add a PLPW1000. That would extend your network over your house's electrical wiring. There are two modules - you'd put one at your router (connecting it with ethernet), and then plug in the WiFi module in the room that has poor coverage. Cost is somewhat higher than an extender, but I think powerline is more likely to solve your problem.
- rk911Nov 09, 2018Aspirantthe book does say it’s a 2.4 ghz wireless but i have both a 2.4 snd 5ghz wifi configured and working. will the N300 or N600 allow me to specify the SSID i want to use?
- StephenBNov 09, 2018Guru - Experienced User
rk911 wrote:
will the N300 or N600 allow me to specify the SSID i want to use?All Netgear extenders let you specify the SSID
rk911 wrote:
the book does say it’s a 2.4 ghz wireless but i have both a 2.4 snd 5ghz wifi configured and working.Curious. Do you know what link speed you have with 5 ghz?
I'd still go with powerline over another extender. You can also set the SSID on the PLPW1000 (and it is also dual band, so you'd get 5 Ghz in the remote room).
- rk911Nov 09, 2018Aspirantref the 5ghz...not offhand. i’ve used it once or twice just ‘cuz. i ‘spose i could shut it down. and ok on being able to configure the SSID.
appreciate your help.
