oldesalt
Aug 06, 2018Aspirant
Loose Antenna On Netgear EX6120 Wifi Range Extender
I have a loose antenna on my Netgear Model EX6120 Range Extender and the only position it will assume is straight down. I assume a nut on the inside of the case has come loose. I don't see any way ...
bibol
Dec 18, 2018Tutor
3M electric tape should do the job for a while + does seem to affect signal, 60/70%
...as long as the cable inside antenna is not broken.
...restored "V" shape.
The device is too hard to tear appart due to 1 microscopic screew...prob. made on purpose.
bibol
Dec 18, 2018Tutor
(+ does NOT seem...)
