oldesalt
Aug 06, 2018Aspirant
Loose Antenna On Netgear EX6120 Wifi Range Extender
I have a loose antenna on my Netgear Model EX6120 Range Extender and the only position it will assume is straight down. I assume a nut on the inside of the case has come loose. I don't see any way ...
oldesalt
Dec 18, 2018Aspirant
Thank you for your reply. You attached a photo but it won't open. Can you please send it again.
bibol
Dec 18, 2018Tutor
sorry already deleted the file, but you can have the same tape here:
plus I saw a youtuber placing a simple elastic bracelet arround the antena swirling base, give it a few curves..and that should held at the angle you d need to...
