Devoratrix
Dec 30, 2020Aspirant
Low internet speed on PLW1000v2 Extender
Hello, I recently got PLW1000v2. Connected it to my modem with cat6 LAN cable. And the other device with antennas is plugged in a room right next to it. Everything is working properly. Connection is...
Dec 30, 2020Guru - Experienced User
what are you doing wrong? Nothing. It can be mulitple issues.
Many people see outlets next to each other or just 1 room over and think "they're close to each other, they should work great". When many times, those outlets have quite a bit of wiring between them because they might be on different circuit breakers. so they might be within 10ft of each other but have 100+ft of wiring in between them. When they're on the same circuit, their performance is quite amazing but add a circuit inbetween them, and performance drops off quite a bit.
also, many things can interfere with powerline. Such as:
high draw appliances
Old/bad/poorly done wiring
gfci outlets
arc fault outlets
surge protectors
electronics going bad
cheap cell phone chargers
distance
Poorly made electronics
This can all inject interference in the powerline system.
There's also a misunderstanding in performance. Powerline numbers are over inflated more than wireless and thats already pretty bad.
I'd take a read through actual testing on the PL1200. Its a step up from yours but should give you some actual performance data to go off that is pretty reliable.
https://www.smallnetbuilder.com/lanwan/lanwan-reviews/32717-netgear-pl1200-powerline-1200-reviewed
Devoratrix
Well, then I might look into my powerline more closely. I'll test more with other electronics plugged out. Because there are a few things working on the same circuit. Thank you for your help. If I don't forget, I'll post if it worked.
