timblack
Mar 01, 2021Tutor
Macbook Pro and Air won't connect to Extender
I have an EX7500/AC2200 Tri-band extender set up on the 2.4 and 5 ghz bands. It is ending out a good strong signal on both frequencies. Netgear firmware was updated last week. However, for some reas...
Mar 02, 2021Guru - Experienced User
Are you using the mesh mode? Meaning you set it up using the "one wifi" function?
If you are, then it relies on the devices own roaming protocols to choose which to connect to.
You can disable this and choose a unique ssid for the extender if you'd like.
