nnmmss
Apr 03, 2013Aspirant
making the WIFI signal stronger
I have weak signal of WIFI in my apartment (cause it is in first floor). is it possible to make the signals stronger by NETGEAR Wireless Extender? Thank you for your attention
Retired_Member
Apr 03, 2013The easy answer is yes, but it gets complicated depending on what you are expecting. If you're surrounded by other WiFi networks you could be let down by the performance seeing how you'll all be interfering with each other. Upgrading your router or relocating it might be a better way to go.
Download inSSIDer this will give you visual picture of other wifi networks which may or may not be a problem.
