MARTIN1277's avatar
MARTIN1277
Maximum Throughput lights keeps going off and not reconnecting Nighthawk x6s 80000
Hi When I connect my Nighthawk the Throughoutput light is on and the internet speeds are high, however after a few hours the light goes off and I have bad connection issues and slow speeds, any ideas?
Thanks
Martin
  • plemans's avatar
    What firmware is on the EX8000?
    Firmware on the R7900P?
    Maybe there's interference. have you tried changing which channel the r7900p----ex8000 connect to each other with?
    • MARTIN1277's avatar
      MARTIN1277
      Hi the firmware on the EX8000 is V1.0.1.206 and says it is up to date, recently updated.
      I am not suyre what you mean by Firmware on the R7900P, if this is teh router, I am using teh Callflow ISP router which they say I have to use.
      Thanks
      Martin
      • plemans's avatar
        Thanks
        Martin
        Sorry, you're post had the R7900P in the signature and I failed and made the assumption that it was your router you were connecting to.
        Which callflow router is it?
