MARTIN1277
Jul 21, 2020Aspirant
Maximum Throughput lights keeps going off and not reconnecting Nighthawk x6s 80000
Hi When I connect my Nighthawk the Throughoutput light is on and the internet speeds are high, however after a few hours the light goes off and I have bad connection issues and slow speeds, any ideas...
Jul 21, 2020Guru - Experienced User
There should be a model number on it.
MARTIN1277
Sorry, it’s a Technicolor DGA4231. Cheers
- plemansJul 21, 2020Guru - Experienced User
Can you set a static address for the EX8000 within the Technicolor DGA4231
- MARTIN1277Jul 21, 2020AspirantI’m not sure I will send. Support request over to them and ask? Thanks
- MARTIN1277Jul 27, 2020Aspirant
I have just chased support as I still haven'y heard back. Any other thoiughts, the speed dramitically reduce when the Maximum Throughput lights goes off.... Do you know what this light actually does, I've tried goggling but doesn't make a lot of sense?
Thanks
Martin
