Chris270
May 29, 2012Aspirant
MBRN 3000 - Repeater
Hi All
This is my first post so sorry if I do give all the correct info.
I have recently bought a MBRN3000 and would like to set it up as an access point or repeater because the current router I have does not have the range to reach the back of the house. Can this be done on this model and, if Yes, then if you could let me know I would really appreciate it.
Thanks so much
Chris
Thanks so much
Chris
- jmizoguchiVirtuosoget extender
wn2500rpt,wn2000rpt,wn3000rp - Chris270Aspirantthanks. I was hoping not to have to spend more money.
I am going to try this option first and if that doesn't work then I will go down the extender option
http://support.netgear.com/app/answers/detail/a_id/965
