pedroenes
Mar 18, 2020Aspirant
Mesh Extend the signal of a Nighthawk R7000P with ethernet cable
Hi ! I Have a Nighthawk R7000P in one side of my house and a old Linksys (with WRT) on other side extending my Wifi Network. - Both are direct connect with a Ethernet Cable. - The DHCP an...
DexterJB
Mar 24, 2020NETGEAR Moderator
Hi pedroenes, you can check the link below for our extenders. All will work with your existing setup. We recommend something with a similar bandwidth capacity or higher for your R7000P.
https://www.netgear.com/home/products/networking/wifi-range-extenders/
Dexter
- pedroenesMar 24, 2020Aspirant
Thank you Dexter.
Kind regards
Pedro
- pedroenesMar 27, 2020Aspirant
Just to be clear.
As I understood on the documentation, if I want to interconnect the R7000P with the AC1900 Extender with a Ethernet cable, I need to set up the extender as Access Point. In that case can I setup the Wifi with the same SSID? (as I do actually with a old router...)
To be a Wireless Extender the interconnection should be done through Wireless WPS.
Is it correct?
Thanks!
PE
