pedroenes
Mar 18, 2020Aspirant
Mesh Extend the signal of a Nighthawk R7000P with ethernet cable
Hi ! I Have a Nighthawk R7000P in one side of my house and a old Linksys (with WRT) on other side extending my Wifi Network. - Both are direct connect with a Ethernet Cable. - The DHCP an...
DexterJB
Mar 24, 2020NETGEAR Moderator
Hi pedroenes, you can check the link below for our extenders. All will work with your existing setup. We recommend something with a similar bandwidth capacity or higher for your R7000P.
https://www.netgear.com/home/products/networking/wifi-range-extenders/
Dexter
pedroenes
Mar 24, 2020Aspirant
Thank you Dexter.
Kind regards
Pedro
