maxx1010
Jun 26, 2020Aspirant
mesh extender EX6400
I think I had my extender working ok then I was adjusting in the settings on my computer. It's not working right now I can't even connect my smart tv to it. I reset my modem and extender. I can't fig...
Jun 26, 2020Guru - Experienced User
Did you say you got it working?
did you set it up via the wps method or manual installtion method.
maxx1010
I used the app method to set up.
now in the mesh settings I did some changing from yesterday and I guess I shouldn't have touched it. I was using the same 2.4 and 5 ghz names . then I did something and everything got messed up. then I changed in the settings to add EXT after each 2.4 and 5ghz. and I got my tv connected that way but I think I want to make everything the same name again but I'm afraid of messing with this anymore. This isn't easy for me honestly.
