KJSS's avatar
KJSS
mesh system
I got the mesh wifi 6 system from costco for 250. Works great. Some areas not as much but most of my house covered. Its about 4200 sq feet. The extra satellites are almost as much as the system.
If I go on ebay and get a used 2pack for example will that work? The satellite will work. But can the router also be used as an extra satellite if disable the router part? Or the router only works as a router?
1 Reply
  • plemans's avatar
    the router can't be used as a satellite as far as I know.
