jpsisko
May 19, 2020Aspirant
Mesh wifi at home with pre-existing router and LAN cables
Hello everybody. I live in a 3 stories house, with several lan cables connecting the 3 floors. I would like to create a MESH network in the house, so to avoid manual selection of which WiFi to conn...
jpsisko
Thanks for the help.
One extra questions that comes to mind: can I install a mesh system and connect the devices via LAN to maximize the speeds?
May 19, 2020Guru - Experienced User
jpsisko wrote:Thanks for the help.
you mean connect devices to the satellites lan?
Not sure exactly what you're meaning but the lan ports are usable
- jpsiskoMay 19, 2020Aspirant
Nope. I meant connect the satellites together via LAN instead than via Radio... So I could have 1 mesh repeater and 1 mesh router, connected together via LAN.
- plemansMay 19, 2020Guru - Experienced User
If your using MESH EXTENDERS and not orbi, you can connect via lan cable but they won't function as a mesh.
to use a hardwired mesh, you'd want the orbi setup that supports an ethernet backhaul.
I was thinking exactly about ORBI setup.
Thanks!
